Einleitung
The USB Port Connector allows devices such as mice and headset to connect to the keyboard instead of the computer itself. You will be removing the back of the keyboard and also the LED reflective panel in order to remove and replace the port connector.
Was du brauchst
Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
Unscrew the two 4.5 mm silver Phillips #1 screws that hold the USB port connector.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
the 2 usb in the keyboard what amp are they running on.. 500mA ? I hope for 1500-2000 mA
And what standard are they ? USB3 ??
can the other part be replaced too. like the power board ?
i think i have a powerboard problem and if I can replace it that would be awesome, as I love my keyboard and im
very very attached to it. I was playing a video game, nothing too harsh , and the lights went out and poof it never came back. never had a problem with this keyboard until 2 and a 1/2 years later that it did this. Its in a non-smoking room and gaming studio always kept very clean.
I would love to fix it to bring it back to life.
