Zum Hauptinhalt wechseln
SteelSeries Arctis 1/7 micro USB port Replaced with USB C port
Was du brauchst
  1. SteelSeries Arctis 1/7 micro USB port Replaced with USB C port, Take off the ear pads: Schritt 1, Bild 1 von 1
    • To take off the ear pads, twist them 90 degrees and carefully pull them off.
  2. SteelSeries Arctis 1/7 micro USB port Replaced with USB C port, Unscrew the plastic cover: Schritt 2, Bild 1 von 1
    • After you've taken off the ear pad there are 3x TR6 screws. Remove these.
  3. SteelSeries Arctis 1/7 micro USB port Replaced with USB C port, Unscrew the PCB and lift the it out: Schritt 3, Bild 1 von 1
    • After the plastic cover has been taken off you should see the PCB, which has 3x PH000 screws. Remove these as well.
    • To lift the PCB out lift from the top side (opposite side of usb port) and push lightly on the volume wheel.
    • Be careful not to break anything while lifting. I broke the usb port off when doing this.
  4. SteelSeries Arctis 1/7 micro USB port Replaced with USB C port, Desolder the micro USB port: Schritt 4, Bild 1 von 2 SteelSeries Arctis 1/7 micro USB port Replaced with USB C port, Desolder the micro USB port: Schritt 4, Bild 2 von 2
    • Note: the micro usb port is on a breakout board which can be removed so that you can more easily solder on the larger points.
    • Desolder the current USB port. (Im not sure what else to write here.)
  5. SteelSeries Arctis 1/7 micro USB port Replaced with USB C port, Solder on the new USB port: Schritt 5, Bild 1 von 2 SteelSeries Arctis 1/7 micro USB port Replaced with USB C port, Solder on the new USB port: Schritt 5, Bild 2 von 2
    • Note: If you don't want to cut into the pcb you should be able to solder extended cables onto the solder board.
    • You need to make sure that you are soldering the port the correct way or you could possibly destroy it when plugging it in to charge.
  6. SteelSeries Arctis 1/7 micro USB port Replaced with USB C port, Results: Schritt 6, Bild 1 von 1
    • The first image is the result of a usb replacement on a Steelseries Artis 1
Abschluss
To reassemble your device, follow some these instructions in reverse order. Don't desolder your new USB port.
2 weitere Personen haben diese Anleitung absolviert.
Kireobat
160 Reputation
1 Anleitung geschrieben
13 Kommentare zur Anleitung
DO NOT DO THAT LIKE THIS!!!
You destroyed PCB and broke layers.
You needed to use a small electronic part socket USB-type-c female instead USB-plate.
Максим Билан - Antwort
Well it may not be the best way to do it, but it works. The headset has worked flawlessly for months now. I am not particularly experienced in soldering, but I wanted to share how I did it.
Kireobat -
Even though it's not the perfect repair, it's good enough for me if it works. Looks easy enough to try and repair them myself. Thanks for sharing dude and I appreciate you giving them a longer life rather than throwing the whole headset into the trash.
Breban Ionut -
My micro usb port came off and I'm planning to repair it. Stumbled upon this guide and wanna make sure if what you did here would also work for mine. Here's what it looks like imgur link. Also do you have any recommendations, tips, or something. Thank you!
Aebrahm Ramos - Antwort
I think it could work. It probably smart to have solder flux ( i didnt have it at the time ). FYI the headset is still working after all this time.
Kireobat -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 23
Letzte 7 Tage: 114
Letzte 30 Tage: 412
Insgesamt: 12,933
