Zum Hauptinhalt wechseln
SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement
Was du brauchst
  1. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: Schritt 1, Bild 1 von 2 SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: Schritt 1, Bild 2 von 2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Circuit Board: Schritt 2, Bild 1 von 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: Schritt 3, Bild 1 von 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: Schritt 5, Bild 1 von 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle Chang
1.152 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S18-G1, White Winter 2019 Mitglied von Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Mitglieder
21 Anleitungen geschrieben
3 Kommentare
any idea where i can buy the circuit parts to both side?
erminio santiago - Antwort
any idea where i can buy Circuit Board Replacement for both side? please
What's the problem that requires circuit board replacement? My left speaker doesn't work checked and all wires connected. Wondering if the circuit board fixes that
bayarea_rooter - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 73
Insgesamt: 9,140
