Zum Hauptinhalt wechseln
Sticky Key Saxophone Fix
Was du brauchst
  1. Sticky Key Saxophone Fix, Sticky Key Saxophone Fix: Schritt 1, Bild 1 von 1
    • Locate sticking key.
  2. Sticky Key Saxophone Fix: Schritt 2, Bild 1 von 1
    • Screws are located down from key.
  3. Sticky Key Saxophone Fix: Schritt 3, Bild 1 von 1
    • Loosen screw slowly and carefully, so that screw isn't lost.
  4. Sticky Key Saxophone Fix: Schritt 4, Bild 1 von 1
    • Test key and note free movement.
  5. Sticky Key Saxophone Fix: Schritt 5, Bild 1 von 1
    • Put saxophone completely together and test out key.
    • If key still sticks repeat previous steps.
Abschluss
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
AlysonStrange
101 Reputation
1 Anleitung geschrieben
Ein Kommentar
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
kwiggins01 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 27
Insgesamt: 1,782
