Zum Hauptinhalt wechseln
Sticky Painted Drawers Fix
Was du brauchst
    1. Sticky Painted Drawers Fix, Sticky Painted Drawers Fix: Schritt 1, Bild 1 von 1
      • Take everything out of the drawer.
      Frag FixBot
      Kommentar hinzufügen
    2. Sticky Painted Drawers Fix: Schritt 2, Bild 1 von 3 Sticky Painted Drawers Fix: Schritt 2, Bild 2 von 3 Sticky Painted Drawers Fix: Schritt 2, Bild 3 von 3
      • Take out the sticky drawer from the cabinet.
      Frag FixBot
    3. Sticky Painted Drawers Fix: Schritt 3, Bild 1 von 3 Sticky Painted Drawers Fix: Schritt 3, Bild 2 von 3 Sticky Painted Drawers Fix: Schritt 3, Bild 3 von 3
      • Grab the drawer.
      • Find the uneven edges and paint build-up.
      Frag FixBot
    4. Sticky Painted Drawers Fix: Schritt 4, Bild 1 von 2 Sticky Painted Drawers Fix: Schritt 4, Bild 2 von 2
      • Wipe down the drawer, getting rid of all dirt and debris.
      • Be careful of splinters.
      Frag FixBot
    5. Sticky Painted Drawers Fix: Schritt 5, Bild 1 von 2 Sticky Painted Drawers Fix: Schritt 5, Bild 2 von 2
      • Sand the edges down using sand paper. This will create smooth edges to get rid of any paint build-up and even out uneven edges.
      • Make sure you sand down all the sides including the bottom.
      Frag FixBot
    6. Sticky Painted Drawers Fix: Schritt 6, Bild 1 von 1
      • Take the wax and put it onto a new towel.
      • Make sure you put a good amount of wax onto the towel.
      Frag FixBot
    7. Sticky Painted Drawers Fix: Schritt 7, Bild 1 von 3 Sticky Painted Drawers Fix: Schritt 7, Bild 2 von 3 Sticky Painted Drawers Fix: Schritt 7, Bild 3 von 3
      • Wax all the sides and edges, creating a smooth and slippery surface.
      Frag FixBot
    8. Sticky Painted Drawers Fix: Schritt 8, Bild 1 von 1
      • Let the wax rest for an hour before returning it to the cabinet.
      • Check if its smooth!
      Frag FixBot
    9. Sticky Painted Drawers Fix: Schritt 9, Bild 1 von 2 Sticky Painted Drawers Fix: Schritt 9, Bild 2 von 2
      • Put the drawer back into its place, and you are done!
      Frag FixBot
Abschluss
Now your drawer should smooth and slippery! Easy to open and close.
Eine weitere Person hat diese Anleitung absolviert.
Molly Osborne
187 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-4, Whithaus Spring 2026 Mitglied von UC Davis, Team 1-4, Whithaus Spring 2026
UCD-WHITHAUS-S26S1G4
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 46
Insgesamt: 136
