Zum Hauptinhalt wechseln
Stihl BG 50 Pull Start Rope Replacement
Was du brauchst
  1. Stihl BG 50 Pull Start Rope Replacement, Pull Start Rope: Schritt 1, Bild 1 von 2 Stihl BG 50 Pull Start Rope Replacement, Pull Start Rope: Schritt 1, Bild 2 von 2
    • Use the Torx T25 screwdriver to remove the three screws holding the orange casing.
    • Remove the orange plastic casing from the rest of the blower.
    Frag FixBot
    Kommentar hinzufügen
  2. Stihl BG 50 Pull Start Rope Replacement: Schritt 2, Bild 1 von 2 Stihl BG 50 Pull Start Rope Replacement: Schritt 2, Bild 2 von 2
    • Hold the starter rope in a U shape.
    • Cut the rope with a knife without letting go of the rope going in the blower.
    • Letting go of the rope will make the rope pull itself rapidly into the starter pulley. This may damage other components.
    Frag FixBot
  3. Stihl BG 50 Pull Start Rope Replacement: Schritt 3, Bild 1 von 2 Stihl BG 50 Pull Start Rope Replacement: Schritt 3, Bild 2 von 2
    • Let the rope go slowly into the starter pulley.
    • Grab the rope from its knot and remove the rope from the starter pulley.
    Frag FixBot
  4. Stihl BG 50 Pull Start Rope Replacement: Schritt 4, Bild 1 von 1
    • Tie a knot at the end of the new starter rope and set it aside.
    Frag FixBot
  5. Stihl BG 50 Pull Start Rope Replacement: Schritt 5, Bild 1 von 1
    • Spin the starter pulley clockwise until a noise is heard.
    • Letting go of the starter pulley will make it spin counter-clockwise. This may result in a small bruise or cut. To avoid this, make sure to have a strong grip on the starter pulley and spin it slowly.
    Frag FixBot
  6. Stihl BG 50 Pull Start Rope Replacement: Schritt 6, Bild 1 von 3 Stihl BG 50 Pull Start Rope Replacement: Schritt 6, Bild 2 von 3 Stihl BG 50 Pull Start Rope Replacement: Schritt 6, Bild 3 von 3
    • Having someone help to insert the rope through the holes will make these steps easier.
    • While holding the starter pulley, insert the end of the rope lacking the knot.
    • When it comes out the other side of the starter pulley, pull it through.
    • Without letting go of the starter pulley, insert the rope through the orange case and pull it taut.
    Frag FixBot
  7. Stihl BG 50 Pull Start Rope Replacement: Schritt 7, Bild 1 von 2 Stihl BG 50 Pull Start Rope Replacement: Schritt 7, Bild 2 von 2
    • Hold the rope taut and let go of the starter pulley.
    • Let go of the rope slowly until about a foot of rope remains outside the casing.
    Frag FixBot
  8. Stihl BG 50 Pull Start Rope Replacement: Schritt 8, Bild 1 von 3 Stihl BG 50 Pull Start Rope Replacement: Schritt 8, Bild 2 von 3 Stihl BG 50 Pull Start Rope Replacement: Schritt 8, Bild 3 von 3
    • Insert the rope inside the pull start handle.
    • Tie a knot at the end of the rope.
    • Let go of the rope.
    • Make sure the pull start handle does not come off before letting go of the rope.
    Frag FixBot
  9. Stihl BG 50 Pull Start Rope Replacement: Schritt 9, Bild 1 von 1
    • Put the orange casing back on the blower.
    • Use the Torx T25 screwdriver to tighten the three screws.
    Frag FixBot
Abschluss
When the pull start rope is pulled, it should wind back. If it does not, a mistake might have occurred when changing the new rope when winding it inside the starter pulley.
3 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
My cord works fine after disassembling fron blower. Put it back together and pulls a little way; then gets stuck, pull more rope,.but I can’t pull all the way out at one time to start the blower. Is there a problem with the wheel or motor
Lindauer93@gmail.com - Antwort Teilen
Cord on blower won’t pull all the way out to start engine on big 50. Took it apart and pull rope pulls fine. Reassembled it and rope won’t pull all the way out to start.
I have a BG 55, 5.0mm cord too big...use the 3.0mm...fyi
Frankfordal - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 32
Letzte 30 Tage: 193
Insgesamt: 10,653
