Einleitung
At some point during your driving experience, your key fob battery is bound to run out, necessitating a replacement. If you experience dim LED light, weak signal, and requires multiple clicks to function, or not functioning at all, it is likely due to a drained battery. The lifespan of the battery should typically range from 3 to 5 years, depending on usage patterns and environmental factors.
The key in use belongs to a 2009 Subaru Legacy, and I believe Subaru Legacy and Outback models from 2010 to 2014 also make use of the same key. Prior to initiating the process, ensure that your key fob corresponds to this specific model. The model information is imprinted on the case beneath the Subaru emblem where the screw reside.
FCC ID: CWTWBU766
IC: 1788D-FWBU766
Was du brauchst
Use a Phillips #00 screwdriver to remove a 5.0 mm screw from the base of the key fob.
Place the flat end of a spudger into the gap between the key blank (metal part) and the case.
Gently pry upward to separate the housing.
Once the case comes apart, turn the key upside down, and the keyless fob should easily come out.
Use a spudger or your fingernails to pry open the four clips securing the keyless fob.
Gently slide a spudger beneath the battery to lift it from the case.
Reassemble the key fob.
