Zum Hauptinhalt wechseln
Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement
    1. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Top Floater Removal: Schritt 1, Bild 1 von 1
      • Remove the black screw by rotating it counterclockwise.
      Frag FixBot
      Kommentar hinzufügen
    2. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: Schritt 2, Bild 1 von 1
      • Hold the device in place and pull up on the floater.
      Frag FixBot
    3. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: Schritt 3, Bild 1 von 1
      • Remove the top floater.
      Frag FixBot
    1. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Battery: Schritt 4, Bild 1 von 1
      • Turn the device upside-down.
      Frag FixBot
    2. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: Schritt 5, Bild 1 von 1
      • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
      Frag FixBot
    3. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: Schritt 6, Bild 1 von 1
      • A push tab holds the battery in.
      Frag FixBot
    4. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: Schritt 7, Bild 1 von 1
      • Push the tab in and pull the battery outward to remove it.
      Frag FixBot
    1. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Lower Panel: Schritt 8, Bild 1 von 1
      • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
      Frag FixBot
    2. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: Schritt 9, Bild 1 von 1
      • Pull the panel forward.
      • You may need to use pry tools to aid in separating the panels.
      Frag FixBot
    1. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Activation Buttons: Schritt 10, Bild 1 von 1
      • There are two action buttons on each side of the main body.
      Frag FixBot
    2. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: Schritt 11, Bild 1 von 1
      • Push on the top outer corner of each action button to pop them out of place.
      Frag FixBot
    3. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: Schritt 12, Bild 1 von 1
      • After each action button is released, pull outward to remove.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023 Mitglied von UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G6
4 Mitglieder
72 Anleitungen geschrieben
3 Kommentare zur Anleitung
Mine have corroded, do you know where I can get x2 replacement activation buttons or just the circular discs??
AMW - Antwort Teilen
Does anyone know where to find a replacement action button or what the metal disc is called on them
Mine have corroded
Ginger Wimberley - Antwort Teilen
Yes, the magnets on the activation buttons corrode too fast and too easily. but they don't even list them for sale on their web page. You need to email or call Sublue support and request a cost including shipping. I'm still waiting for the email estimate.
Robert McRae - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 27
Letzte 30 Tage: 59
Insgesamt: 682
