Zum Hauptinhalt wechseln
Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement
    1. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Top Floater Removal: Schritt 1, Bild 1 von 1
      • Remove the black screw by rotating it counterclockwise.
      Frag FixBot
      Kommentar hinzufügen
    2. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: Schritt 2, Bild 1 von 1
      • Hold the device in place and pull up on the floater.
      Frag FixBot
    3. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: Schritt 3, Bild 1 von 1
      • Remove the top floater.
      Frag FixBot
    1. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Battery: Schritt 4, Bild 1 von 1
      • Turn the device upside-down.
      Frag FixBot
    2. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: Schritt 5, Bild 1 von 1
      • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
      Frag FixBot
    3. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: Schritt 6, Bild 1 von 1
      • A push tab holds the battery in.
      Frag FixBot
    4. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: Schritt 7, Bild 1 von 1
      • Push the tab in and pull the battery outward to remove it.
      Frag FixBot
    1. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Lower Panel: Schritt 8, Bild 1 von 1
      • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
      Frag FixBot
    2. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: Schritt 9, Bild 1 von 1
      • Pull the panel forward.
      • You may need to use pry tools to aid in separating the panels.
      Frag FixBot
    1. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Safety Switch: Schritt 10, Bild 1 von 1
      • Place the main body panel with the handle that holds the safety switch towards you. Pull the white tab of the right and pull towards you from the top of the safety switch.
      Frag FixBot
Abschluss
UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023 Mitglied von UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G6
4 Mitglieder
72 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 316
