Zum Hauptinhalt wechseln
Einleitung
If the seat gets dirty, or the fabric is damaged, this guide will show you how to take the seat out.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two silver 12.7 mm  #01 screws (1 on each side) holding the back of the seat to the frame. Remove the two silver 12.7 mm  #01 screws (1 on each side) holding the back of the seat to the frame.
    • Remove the two silver 12.7 mm #01 screws (1 on each side) holding the back of the seat to the frame.
  2. Unscrew the four silver 12.7 mm #01 screws (2 on each side)  holding the fabric along the handlebars on both sides.
    • Unscrew the four silver 12.7 mm #01 screws (2 on each side) holding the fabric along the handlebars on both sides.
  3. Unscrew the four silver 12.7 mm #01 (2 on each side) screws on the bottom of the frame where the fabric is held in place.
    • Unscrew the four silver 12.7 mm #01 (2 on each side) screws on the bottom of the frame where the fabric is held in place.
  4. After checking that all screws are unattached, pull the seat off. After checking that all screws are unattached, pull the seat off.
    • After checking that all screws are unattached, pull the seat off.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Cal Poly, Team 11-5, Forte Fall 2015 Mitglied von Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
4 Mitglieder
3 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 11
Insgesamt: 1,172
