Einleitung
All that is needed to replace the battery is a screwdriver.
Was du brauchst
Place the lamp LED side down on a clean workspace.
Remove the screws holding the casing together using a Phillips #1 Screwdriver.
Locate the battery.
Gently lift the battery from the device.
Locate the clip attaching the battery pack to the circuit board.
Use tweezers to remove the portion of the clip attached to the battery.
Align the black wire of the new battery towards the center of the device.
Press down firmly on the clip to insure that it is properly connected.
Seat the battery in the orange component so that the short end of the battery pack is touching the foam bumper.
6 weitere Personen haben diese Anleitung absolviert.
8 Kommentare
please help in finding the life p04 battery,3.2v ,1500 mah,batch #20309
as my solar lights battery is dead..iam unable to find out whr i will get a new one
where to get the battery spare part?
Howi can get 6.6 v sunking pro battery?please help me.
