Einleitung
Use this guide to replace the seals on your device to prevent damages to the internal components.
Was du brauchst
Place the lamp LED side down on a clean workspace.
Remove the screws holding the casing together using a Phillips #1 Screwdriver.
On the clear upper half, remove the black O-ring
Place the new O-ring, making sure it is smooth all the way around
Remove the rubber stand holders.
Place the new stand holders, making sure the wings of the holder are in the second opening
