Zum Hauptinhalt wechseln
Sunbeam Mini Pie Maker FPSBPMM980 Disassembly
Was du brauchst
  1. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 1, Bild 1 von 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 1, Bild 2 von 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 1, Bild 3 von 3
    • Open the pie maker.
    • Remove four 4 mm screws holding the crescent-shaped black plastic plate in place with a Phillips #1 screwdriver.
    • Remove the black crescent-shaped plastic plate.
  2. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 2, Bild 1 von 2 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 2, Bild 2 von 2
    • Repeat the previous step to remove the upper black crescent-shaped plastic plate from the upper half of the unit.
    • The pie maker's symmetrical construction may cause confusion—in this image the pie maker is resting on its upper half.
  3. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 3, Bild 1 von 1
    • Remove the four 4 mm screws located directly on either side of the hinges with a Phillips #1 screwdriver.
    • Successfully removed screws will allow for the separation of the pan component from the outer plastic shell.
  4. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 4, Bild 1 von 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 4, Bild 2 von 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 4, Bild 3 von 3
    • Remove the final two 4 mm screws from the circular black plastic bottom base plate with a Phillips #1 screwdriver.
    • Remove the black plastic base.
  5. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 5, Bild 1 von 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 5, Bild 2 von 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 5, Bild 3 von 3
    • Disconnect the two red and green incandescent lights from their fixtures by popping them out of their red plastic cradles.
  6. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 6, Bild 1 von 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 6, Bild 2 von 3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 6, Bild 3 von 3
    • Examine successfully disassembled Sunbeam Mini Pie Maker FPSBPMM980.
    • If desired, remove insulatory coated paper cut outs to more easily access heating coils.
  7. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: Schritt 7, Bild 1 von 1
    • Examine electronics schematic.
    • The Sunbeam Pie Maker utilizes four heating coils to bring miniature pies to an internal temperature of 175+ F. The pies are placed in the appliance after pre-heating, and are cooked for approximately 10 minutes, or until golden brown. The machine begins pre-heating upon being plugged in, signifying it is receiving power with the red light.
Abschluss
To reassemble your device, follow these instructions in reverse order. Happy fixing!
Julian Kelly
246 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 110
