Einleitung
This guide will include a walkthrough of how to change the screen of your tablet. It will include step by step process with notes on tools and materials needed.
Was du brauchst
Hold the device so the left side is facing towards you (like in the picture shown) so the two 4mm PH001 screws are exposed and easier to access.
Carefully pry up one of the top corners of the screen with a plastic spudger (prying tool). Slide the tool along the edges to release it from the housing.
The screen is still connected to the motherboard. Use force with caution.
Gently turn screen over, to the side, to reveal the ZIF connector attached to the motherboard.
Using the prying tool, slide the black clip out. Pull the ZIF connector out and to the left, the screen is now detached from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
