Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will show the steps involved in replacing the speaker.
  1. Press firmly on lower portion of the back cover and slide the cover towards the bottom to remove cover.
    • Press firmly on lower portion of the back cover and slide the cover towards the bottom to remove cover.
  2. Pull on the plug carefully until it releases from the port and simply pull the battery out after.
    • Pull on the plug carefully until it releases from the port and simply pull the battery out after.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Pry open the casing with a plastic opening tool .
    • Pry open the casing with a plastic opening tool .
  5. Unscrew the five 4.5 mm screws to allow access to the motherboard. Lift the motherboard and set it onto the backside of the screen.
    • Unscrew the five 4.5 mm screws to allow access to the motherboard.
    • Lift the motherboard and set it onto the backside of the screen.
  6. Pry the speaker out of retainer clip with iFixit pry tool.
    • Pry the speaker out of retainer clip with iFixit pry tool.
  7. Pry the  speaker clip from the motherboard using tweezers.
    • Pry the speaker clip from the motherboard using tweezers.
Abschluss
Austin_Parkes
337 Reputation
3 Anleitungen geschrieben
IUPUI, Team S4-G4, Baechle Spring 2018 Mitglied von IUPUI, Team S4-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G4
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 67
