Zum Hauptinhalt wechseln
Super Nintendo Cartridge Replacement
Was du brauchst
  1. Super Nintendo Cartridge Replacement, Cartridge: Schritt 1, Bild 1 von 2 Super Nintendo Cartridge Replacement, Cartridge: Schritt 1, Bild 2 von 2
    • On the bottom front corners of the cartridge you should see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out.
    • Once the screws are out, slide the front part of the plastic casing down to clear the tabs on the top of the case.
    • The two halves of the case should open easily.
  2. Super Nintendo Cartridge Replacement: Schritt 2, Bild 1 von 1
    • At this point the game board and pins are freely accessible.
    • Here you can fully clean the pin set and inspect for damage to the circuit board.
    • Cleaning the pins is the easiest part; use a cotton swab and either a rich mixture isopropyl alcohol or Brasso. Other people swear by an eraser(the white kind), but it can lead to damage if you're not careful. Personally, Brasso works the best.
  3. Super Nintendo Cartridge Replacement: Schritt 3, Bild 1 von 2 Super Nintendo Cartridge Replacement: Schritt 3, Bild 2 von 2
    • NOTE: The top edges of the board are made asymmetrically so it can only go into the casing one way. Near the Blue Circles
    • Games with battery backup (allowing for save games to be stored in SRAM) allow access to the battery at this point for replacement. Most of the time the battery is a button cell: CR2032.
    • The battery is soldered in. You will have to break it out and re-solder the new battery in.
Abschluss
To reassemble the cartridge, follow these instructions in reverse order.
22 weitere Nutzer:innen haben diese Anleitung absolviert.
BWest
3.375 Reputation
2 Anleitungen geschrieben
OPEN Mitglied von OPEN
Community
82 Mitglieder
25 Anleitungen geschrieben
Ein Kommentar
Nintendo fix talk Nancy Places Nick III Fix SNES Alive Green
nj8324805 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 35
Letzte 30 Tage: 145
Insgesamt: 34,165
