Einleitung
Replacing the battery in the SuperTooth buddy hands-free system.
Was du brauchst
Remove the two screws on the right.
There is also a small screw to the left of the green button
Be careful when lifting off the cover so as not to damage the two thin speaker cables.
Carefully remove the two screws holding the circuit board in place.
The battery is located under the circuit board
Order a replacement battery online.
Li-ION 3.7V 650mAh 2.41 Wh
Make sure that the new battery has the same dimensions as the old one. (In this case it was approx. 50mm x 30mm x 4mm.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
oldturkey03 hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Ein Kommentar
Ottime istruzioni per lo smontaggio. Grazie. Fino ad ora non ho trovato la batteria sostitutiva su internet. Spero di trovarla.
