Zum Hauptinhalt wechseln
Superficial Drywall Ceiling Crack Repair
Was du brauchst
  1. Superficial Drywall Ceiling Crack Repair, Superficial Drywall Ceiling Crack Repair: Schritt 1, Bild 1 von 2 Superficial Drywall Ceiling Crack Repair, Superficial Drywall Ceiling Crack Repair: Schritt 1, Bild 2 von 2
    • Use a utility knife or five-in-one to remove loose paint or drywall from inside the crack.
    • Don’t gouge the ceiling but firmly scrape parallel to the crack. Scraping perpendicularly to the crack will only cause more damage.
  2. Superficial Drywall Ceiling Crack Repair: Schritt 2, Bild 1 von 3 Superficial Drywall Ceiling Crack Repair: Schritt 2, Bild 2 von 3 Superficial Drywall Ceiling Crack Repair: Schritt 2, Bild 3 von 3
    • Use mesh tape to tape over the crack.
    • Try to use long pieces of tape, if possible taping the entire crack with one piece.
    • It is also important to keep each piece of tape centered on the crack.
  3. Superficial Drywall Ceiling Crack Repair: Schritt 3, Bild 1 von 2 Superficial Drywall Ceiling Crack Repair: Schritt 3, Bild 2 von 2
    • Use either a five-in-one or a putty knife to spread the compound.
    • Spread drywall joint compound over the tape so that it appears flat.
    • Use more joint compound than you need rather than less. You will sand off excess later.
    • Make sure to cover the tape completely.
  4. Superficial Drywall Ceiling Crack Repair: Schritt 4, Bild 1 von 2 Superficial Drywall Ceiling Crack Repair: Schritt 4, Bild 2 von 2
    • After the compound has completely dried sand down any ridges that resulted from the putty knife.
    • This step will be messy! Everything in the room will get some dust on it, so either use dropcloths or be ready to clean when you're done.
    • Also, be careful not to get dust in your eyes, or inhale dust. You may wish to wear goggles and a dust mask.
    • Don’t sand into the tape.
    • You still want the compound to cover the tape and its contours completely.
  5. Superficial Drywall Ceiling Crack Repair: Schritt 5, Bild 1 von 1
    • Prime and paint the ceiling.
    • Use a primer and paint that has been matched to your ceiling by a paint shop.
    • The primer can be any color that is the same or lighter than your ceiling color.
Abschluss
It is important to note that a crack in drywall may indicate a more critical problem with the framing in your walls or ceiling. Please do not assume that this repair will prevent further cracking.
25 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 30-1, Green Spring 2015 Mitglied von Cal Poly, Team 30-1, Green Spring 2015
CPSU-GREEN-S15S30G1
4 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
Is it ok to remove the excess compound and smooth with a damp sponge?
kjratatat - Antwort
I just rocked my third ceiling. The first looked like "before" in some spots; the next 2 are flawless. The secret is to put on very thin layers, and lots of them. Of course this takes a long time to dry each coat. But if you put the mud on thick it will shrink and crack later, plus you have a lot to scrape off and then you still have to fill in low spots.
If you use a sponge first, you can end up with a lumpy mess. Level it with a 12 inch knife until it's nearly flat, then on the last coat skim it over and smooth with the sponge.
James Van Damme - Antwort
My popcorn ceiling has peeled. I took away those rough edges. Can I spray on the popcorn ceiling. It's just small sections.
Gloria Smith - Antwort
If I was to buy compound from Home Depot or lowe’s, what would I be looking for? Is there a brand that is recommended?
GCots - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 26
Letzte 7 Tage: 217
Letzte 30 Tage: 1,108
Insgesamt: 133,737
