Zum Hauptinhalt wechseln
Supersonic Matrix SC-91MID Screen Replacement
Was du brauchst
  1. Supersonic Matrix SC-91MID Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Supersonic Matrix SC-91MID Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Place the plastic opening tool between the screen and the main component and pry open between the two. Once removed place the main component in a safe place and continue working on the screen section.
    • Be aware of the ribbon cables when removing the display screen from the main component.
  2. Supersonic Matrix SC-91MID Screen Replacement: Schritt 2, Bild 1 von 3 Supersonic Matrix SC-91MID Screen Replacement: Schritt 2, Bild 2 von 3 Supersonic Matrix SC-91MID Screen Replacement: Schritt 2, Bild 3 von 3
    • Place the plastic opening tool between the metal screen plate and the black front casing.
    • There are small clips where the plastic opening tool can be placed to help pry the screen from the casing.
  3. Supersonic Matrix SC-91MID Screen Replacement: Schritt 3, Bild 1 von 3 Supersonic Matrix SC-91MID Screen Replacement: Schritt 3, Bild 2 von 3 Supersonic Matrix SC-91MID Screen Replacement: Schritt 3, Bild 3 von 3
    • Continue to slide the opening tool along the length of the casing until there is a clear separation between the screen and the cover (as shown in the third image).
  4. Supersonic Matrix SC-91MID Screen Replacement: Schritt 4, Bild 1 von 1
    • Once there is a clearing, carefully remove the screen from the black cover. You now have separated the screen from the tablet device and and are now ready to replace screen.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Norikuni Nishikawa
139 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G1, Wilson Spring 2018 Mitglied von IUPUI, Team S1-G1, Wilson Spring 2018
IUPUI-WILSON-S18S1G1
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 409
