Einleitung
If your touchscreen does not respond to a finger or stylus, you need to replace the touchscreen sensor. As a prerequisite, use the motherboard replacement guide to reveal the touchscreen after opening the back.
Was du brauchst
Pull the yellow ribbon cable to dislodge the screen from the plastic screen cover.
Tear the yellow tape in order to make the front and back covers free to disassemble.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Separate the two covers.
Put aside the white sheets.
Use the tweezers to remove the sting glue and separate the glue from the sensor.
