Zum Hauptinhalt wechseln
Einleitung
Prereq-only guide for disconnecting the supply tube from a gravity flush toilet.
  1. Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight. The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  2. Place a bucket under the supply tube to catch any dripping water. Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank. Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
Abschluss
Ron Davis
27.033 Reputation
13 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 95
