Einleitung
This is a guide to replace your devices surflink port. This is a simple and short guide that doesn't require many tools. You may need to replace the surflink ort if it is unresponsive, but don't worry as this guide will only take a short amount of time.
Was du brauchst
Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
Disconnect the battery cable by lifting the pull tab until it "clicks."
Remove the left I/O bracket by unscrewing the the three M1109237 screws with your T3 Torx Screwdriver.
Remove the two M1149393 screws that secure the ribbon cable with your T3 Torx screwdriver.
Lightly disconnect the flat-top connector by lifting it straight up with an opening tool.
Remove the two M1149393 screws that secure the Surflink port with your T3 Torx screwdriver.
Lift the surflink port out and up with your tweezers.
Ein Kommentar
Dont even bother reading this unless you already have aquired the surflink port. They are basically impossible to get the parts through ifixit and microsoft. in europe at least.
