Zum Hauptinhalt wechseln
Surface Studio M.2 SSD Replacement
Was du brauchst
  1. Surface Studio M.2 SSD Replacement, M.2 SSD: Schritt 1, Bild 1 von 3 Surface Studio M.2 SSD Replacement, M.2 SSD: Schritt 1, Bild 2 von 3 Surface Studio M.2 SSD Replacement, M.2 SSD: Schritt 1, Bild 3 von 3
    • Lay the Surface face down on a padded surface
    • Be careful not to scratch the screen when laying it face down
    • Remove the four rubber feet at each corner concealing the Torx screws
    • Remove the four Torx screws under the rubber feet.
    • Two screws on the upper corners are longer than two screws on the lower corners.
    • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
  2. Surface Studio M.2 SSD Replacement: Schritt 2, Bild 1 von 2 Surface Studio M.2 SSD Replacement: Schritt 2, Bild 2 von 2
    • Remove five torx screws holding the two fans to the midframe
    • Remove the two fans
    • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
    • Four large torx screws and four small torx screws hold the midframe to the upper frame.
    • Remove four large torx screws holding the midframe
    • Remove four small torx screws holding the midframe
  3. Surface Studio M.2 SSD Replacement: Schritt 3, Bild 1 von 1
    • Slowly remove the midframe
    • Be careful, the speaker on the midframe is still attached to the motherboard
    • Detach the connectors for the two fans and the speaker
  4. Surface Studio M.2 SSD Replacement: Schritt 4, Bild 1 von 2 Surface Studio M.2 SSD Replacement: Schritt 4, Bild 2 von 2
    • With the midframe removed, the M.2 SSD is now accessible
    • Remove a torx screw holding the M.2 holding the SSD to the motherboard
    • Pull the SSD straight back
    • Do not pull the SSD upward or risk damaging the M.2 socket
    • The M.2 socket is compatible with most SATA III, PCIe ACHI, and PCIe NVMe in the M.2 2280 form factor
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
The Raptor
6.276 Reputation
6 Anleitungen geschrieben
21 Kommentare zur Anleitung
I know that one of the very first questions would be: Does the M.2 slot supports PCIe NVMe ?
The answer is: Yes it does.
The Raptor - Antwort
But it does not mean that you can get the drive to run in NVMe model.
There does not appear to be a setting to enable NVMe model for the drive.
John -
Does it support bootable NVMe?
Mark Smith - Antwort
@msmith4099 @theofficemaven
Sure. When installing Windows, choose to install Windows to "Drive 1" instead of "Drive 0"
The Raptor -
Is there any raid options that need to be configured?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 33
Letzte 30 Tage: 140
Insgesamt: 13,193
