Was du brauchst
First you have to remove the screws with an Imbus key (size 4) on the left and right side.
The screws can now be removed from the battery with a screwdriver PH 3 (alternatively a wrench or a socket wrench size 10 can be used).
Attention! There are nuts under the screws. These are not attached, so care must be taken when removing the screws that the nuts are not lost.
Before installation, both battery poles should be treated with polar grease or polish spray. Otherwise it can lead to corrosion, which can lead to contact problems.
After the positive pole is attached, it should be protected with the cover provided. If the cover is defective, it must be replaced. This protection is also a relevant criterion for TÜV.
After the plus pole is attached and protected, the negative pole can be attached.
To put the device back together follow the steps in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
