Zum Hauptinhalt wechseln
SwagTron T1 Back Panels Replacement
Was du brauchst
  1. SwagTron T1 Back Panels Replacement, Back Panels: Schritt 1, Bild 1 von 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Back Panels Replacement: Schritt 2, Bild 1 von 3 SwagTron T1 Back Panels Replacement: Schritt 2, Bild 2 von 3 SwagTron T1 Back Panels Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Back Panels Replacement: Schritt 3, Bild 1 von 3 SwagTron T1 Back Panels Replacement: Schritt 3, Bild 2 von 3 SwagTron T1 Back Panels Replacement: Schritt 3, Bild 3 von 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
Abschluss
Adrian Abarca
360 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G5, Banghart Spring 2017 Mitglied von Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 663
