Zum Hauptinhalt wechseln
SwagTron T1 Gyroscope Replacement
Was du brauchst
  1. SwagTron T1 Gyroscope Replacement, Back Panels: Schritt 1, Bild 1 von 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Gyroscope Replacement: Schritt 2, Bild 1 von 3 SwagTron T1 Gyroscope Replacement: Schritt 2, Bild 2 von 3 SwagTron T1 Gyroscope Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Gyroscope Replacement: Schritt 3, Bild 1 von 3 SwagTron T1 Gyroscope Replacement: Schritt 3, Bild 2 von 3 SwagTron T1 Gyroscope Replacement: Schritt 3, Bild 3 von 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Gyroscope Replacement, Gyroscope: Schritt 4, Bild 1 von 2 SwagTron T1 Gyroscope Replacement, Gyroscope: Schritt 4, Bild 2 von 2
    • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
  5. SwagTron T1 Gyroscope Replacement: Schritt 5, Bild 1 von 1
    • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
  6. SwagTron T1 Gyroscope Replacement: Schritt 6, Bild 1 von 3 SwagTron T1 Gyroscope Replacement: Schritt 6, Bild 2 von 3 SwagTron T1 Gyroscope Replacement: Schritt 6, Bild 3 von 3
    • Carefully remove the gyroscope component from the SwagTron.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Teagan Allen
426 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G5, Banghart Spring 2017 Mitglied von Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Mitglieder
5 Anleitungen geschrieben
5 Kommentare
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - Antwort
Amazon.com Keyword: CertiCable
Jesse Griffis -
Where do you get the replacement?
Brittany Conner - Antwort
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - Antwort
I just got mine today and after the first hour I ran into a shoe and then I tried recalibrating it but it was no use. If someone knows what’s going on please tell me! Thank you :)
Elia Leon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 38
Insgesamt: 7,216
