Einleitung
This guide will show you how to replace the gyroscope component of your SwagTron T1. This may be necessary if the self-balancing function of your hoverboard is not working correctly. Before attempting this replacement, recalibrate your SwagTron. If the problem persists, continue with this replacement. This replacement can be done for the gyroscope component on either side of your SwagTron T1.
Was du brauchst
Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
Carefully lift the panels off
Follow the wires from the panels to the motherboard.
You may need to cut any zip ties that are holding the wires together.
There is one connection on the battery side and three on the other side that must be removed.
Your back panels are now completely removed.
Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Amazon.com Keyword: CertiCable
Where do you get the replacement?
Can’t find gyroscope for a t5 hover board please help.
