Einleitung
This guide will show you how to remove and replace the outer shell of your SwagTron T1
Was du brauchst
Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
Carefully lift the panels off
Follow the wires from the panels to the motherboard.
You may need to cut any zip ties that are holding the wires together.
There is one connection on the battery side and three on the other side that must be removed.
Your back panels are now completely removed.
Unscrew the twelve 10mm screws that connect the metal chassis to the top plastic panel.
Turn the SwagTron over and disconnect the wires from the motherboard.
Follow the wires to the underside of the SwagTron.
Carefully remove the cord and the panel together.
All the panels are now free from the SwagTron.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
Where did you ind a replacement shell for the Swagtron T1? I need to buy a new one, but can’t seem to find a place to buy it online.
Where can I buy a Swagtron T1 replacement shell?
Syd any luck finding a replacement shell? I need to order the same kind and cannot find it online.
Craig -
Amazon.com Keyword: CertiCable
