Einleitung
This guide will outline how to replace the wheel of the SwagTron T1 hoverboard. This may be necessary for any critical damage done to the hoverboard's wheel.
Was du brauchst
Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
Carefully lift the panels off
Follow the wires from the panels to the motherboard.
You may need to cut any zip ties that are holding the wires together.
There is one connection on the battery side and three on the other side that must be removed.
Your back panels are now completely removed.
Using your Phillips #2 screwdriver, remove the four 1cm screws that attach the gyroscope and its black case to the hoverboard.
Carefully remove this component and set it off to the side.
Using your H 6.0 allen wrench, remove the four 20mm black bolts shown in the picture.
Take off the iron plate holding the wheel in place.
Remove the Motor/Wheel and set it aside close by to the hoverboard.
Slide the protective plastic off the connectors on the marked wires (green, blue, and yellow) using your hands or a set of tweezers.
Separate the set of marked green, blue, and yellow wires from their connectors.
Finally separate the last connector shown on the left.
Your wheel is completely removed; slide in a new Motor/Wheel into the slot and follow the previous steps in reverse order.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Where do you get replacement wheels?
Mine won't stop beeping?? Fully charged.
