Einleitung
If your Swagtron T3 battery is not working, this guide will show you how to replace it. To avoid electric shock, discharge the capacitors using the capacitor discharge tool before making any changes to your Swagtron.
Was du brauchst
Flip the Swagtron so that the footpads are facing the ground.
Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
Slowly lift the backside cover.
Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
Three cables on the motherboard side.
Two red cables with white connectors and one white cable with a white connector.
One yellow cable with a black connector on the battery side.
Unscrew the four 9.4 mm Phillips #1 machine screws attaching the battery to the base of the Swagtron T3.
Detach the two cables connecting the battery to the Swagtron by pinching the connector clips and pulling the cables apart:
One red and black cable with a yellow connector.
One blue cable with a black connector.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
10 Kommentare
I can’t find a battery with the two wire harnesses coming out of the pack. Where can I order one?
Where Can I purchase a replacement batter for the T3
Leandre - June 18
Swagtron doesn’t sell the silver battery (even if you email them) I bought one from HoverboardRepair.com and it worked. Only difference is the small wire doesn’t come on the new battery but my hoverboard has worked just fine and I replaced the battery months ago.
