Zum Hauptinhalt wechseln
Swann Doorphone Video Intercom Camera Replacement
Was du brauchst
  1. Swann Doorphone Video Intercom Camera Replacement, Camera: Schritt 1, Bild 1 von 3 Swann Doorphone Video Intercom Camera Replacement, Camera: Schritt 1, Bild 2 von 3 Swann Doorphone Video Intercom Camera Replacement, Camera: Schritt 1, Bild 3 von 3
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  2. Swann Doorphone Video Intercom Camera Replacement: Schritt 2, Bild 1 von 2 Swann Doorphone Video Intercom Camera Replacement: Schritt 2, Bild 2 von 2
    • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
  3. Swann Doorphone Video Intercom Camera Replacement: Schritt 3, Bild 1 von 3 Swann Doorphone Video Intercom Camera Replacement: Schritt 3, Bild 2 von 3 Swann Doorphone Video Intercom Camera Replacement: Schritt 3, Bild 3 von 3
    • Remove the other wires using the same steps as the blue wire.
    • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
    • Remove the back plate by pulling the plate away from the device.
  4. Swann Doorphone Video Intercom Camera Replacement: Schritt 4, Bild 1 von 2 Swann Doorphone Video Intercom Camera Replacement: Schritt 4, Bild 2 von 2
    • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
  5. Swann Doorphone Video Intercom Camera Replacement: Schritt 5, Bild 1 von 2 Swann Doorphone Video Intercom Camera Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
    • Pull slowly in the direction of the cables until the connector is no longer attached.
  6. Swann Doorphone Video Intercom Camera Replacement: Schritt 6, Bild 1 von 2 Swann Doorphone Video Intercom Camera Replacement: Schritt 6, Bild 2 von 2
    • Remove the camera from the device.
Abschluss
Emily Stenke
555 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S2-G4, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Mitglieder
5 Anleitungen geschrieben
15 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 696
