Einleitung
This guide can be used to help replace a broken or stuck Doorbell located on the outside camera on your Swann Doorphone Video Intercom.
Was du brauchst
Flip the outdoor camera over so that the underside is facing up.
Remove the back cover by grabbing the sides of the camera and pulling towards your body.
With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
While pressing the gray square button, remove the blue wire from the first opening under the button.
Remove the other wires using the same steps as the blue wire.
Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
Remove the back plate by pulling the plate away from the device.
Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
Pull slowly in the direction of the cables until the connector is no longer attached.
Using your fingers, take hold of the wire connector attached to the main board
Pull slowly towards your body until the connector is no longer attached.
Using the JIS #0 screwdriver, remove the 2 mm screws diagonal from each other from the main board.
Gently pull the main board away from the inside of the device and leave to the side.
Using the JIS #0 screwdriver, remove the 1mm screws from each side of the doorbell spring-loaded cover-plate
Remove the black circular doorbell cover-plate.
Remove the metal circular doorbell button.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Thanks for posting. It is great to find new sources of doorbell replacement information.
