Zum Hauptinhalt wechseln
Swann Wi-Fi Indoor Security Camera Case Replacement
Was du brauchst
  1. Swann Wi-Fi Indoor Security Camera Case Replacement, Case: Schritt 1, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera Case Replacement, Case: Schritt 1, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera Case Replacement, Case: Schritt 1, Bild 3 von 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Case Replacement: Schritt 2, Bild 1 von 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Case Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 300
