Zum Hauptinhalt wechseln
Sylvania SDVD9004 CD Drive Replacement
Was du brauchst
  1. Sylvania SDVD9004 CD Drive Replacement, CD Drive: Schritt 1, Bild 1 von 3 Sylvania SDVD9004 CD Drive Replacement, CD Drive: Schritt 1, Bild 2 von 3 Sylvania SDVD9004 CD Drive Replacement, CD Drive: Schritt 1, Bild 3 von 3
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
    • Wedge head lightly between drive and bottom of tab.
    • Repeat on both sides.
    • Gently pull out ribbon
  2. Sylvania SDVD9004 CD Drive Replacement: Schritt 2, Bild 1 von 1
    • Drive Removal
    • Use Philip's screw driver to remove three 7 mm screws.
    • Rotate counter clockwise to loosen screws.
  3. Sylvania SDVD9004 CD Drive Replacement: Schritt 3, Bild 1 von 1
    • Follow the red and black cables to the motherboard point of attachment.
    • Use a Flat head screwdriver.
    • Place head of driver into the grove of plug and port.
    • Wedge on all sides evenly to work out plug slowly.
    • Remove small and large plugs.
Abschluss
Sarah Henry
417 Reputation
4 Anleitungen geschrieben
Baylor, Team 5-10, Williams Fall 2016 Mitglied von Baylor, Team 5-10, Williams Fall 2016
BU-WILLIAMS-F16S5G10
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 574
