Zum Hauptinhalt wechseln
Sylvania SDVD9004 Motherboard Replacement
Was du brauchst
  1. Sylvania SDVD9004 Motherboard Replacement, Back cover: Schritt 1, Bild 1 von 1
    • Remove ten 7mm Phillips #0 screws.
    • Remove four 5mm Phillips #0 screws.
  2. Sylvania SDVD9004 Motherboard Replacement: Schritt 2, Bild 1 von 2 Sylvania SDVD9004 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Flip the device over.
    • Lift the top.
  3. Sylvania SDVD9004 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
  4. Sylvania SDVD9004 Motherboard Replacement, CD Drive: Schritt 4, Bild 1 von 3 Sylvania SDVD9004 Motherboard Replacement, CD Drive: Schritt 4, Bild 2 von 3 Sylvania SDVD9004 Motherboard Replacement, CD Drive: Schritt 4, Bild 3 von 3
    • Wedge head lightly between drive and bottom of tab.
    • Repeat on both sides.
    • Gently pull out ribbon
  5. Sylvania SDVD9004 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Drive Removal
    • Use Philip's screw driver to remove three 7 mm screws.
    • Rotate counter clockwise to loosen screws.
  6. Sylvania SDVD9004 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Follow the red and black cables to the motherboard point of attachment.
    • Use a Flat head screwdriver.
    • Place head of driver into the grove of plug and port.
    • Wedge on all sides evenly to work out plug slowly.
    • Remove small and large plugs.
  7. Sylvania SDVD9004 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 3 Sylvania SDVD9004 Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 3 Sylvania SDVD9004 Motherboard Replacement, Motherboard: Schritt 7, Bild 3 von 3
    • Remove Ribbon from Rear Panel
  8. Sylvania SDVD9004 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Anchor screw removal
    • Use Philip's head screwdriver
    • Place head of driver into screw on mother board.
    • Remove all four screws
  9. Sylvania SDVD9004 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Lift motherboard to expose battery
Abschluss
Sarah Henry
417 Reputation
4 Anleitungen geschrieben
Baylor, Team 5-10, Williams Fall 2016 Mitglied von Baylor, Team 5-10, Williams Fall 2016
BU-WILLIAMS-F16S5G10
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 384
