Zum Hauptinhalt wechseln
Synchronisationsprobleme am linken Joy-Con lösen
Was du brauchst
Videoanleitungen
Abschluss
Um dein Gerät wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
12 weitere Personen haben diese Anleitung absolviert.
en de
100%
Hier starten ›
7 Kommentare zur Anleitung
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - Antwort Teilen
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon - Antwort Teilen
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - Antwort Teilen
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - Antwort Teilen
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 111
Letzte 30 Tage: 1,030
Insgesamt: 52,302
