Zum Hauptinhalt wechseln
Synology DS218play - a complete disassembly in rules
Was du brauchst
  1. Synology DS218play - a complete disassembly in rules, Presentation: the different faces of the case: Schritt 1, Bild 1 von 2 Synology DS218play - a complete disassembly in rules, Presentation: the different faces of the case: Schritt 1, Bild 2 von 2
    • Here are the different interesting faces of the case: front (led indicator, power button), rear (connectors, fans, power).
    • On the back you'll see the power connector, two USB ports, an RJ45 port and the Kensington slot (K-lock).
  2. Synology DS218play - a complete disassembly in rules, Removing the case cover: Schritt 2, Bild 1 von 3 Synology DS218play - a complete disassembly in rules, Removing the case cover: Schritt 2, Bild 2 von 3 Synology DS218play - a complete disassembly in rules, Removing the case cover: Schritt 2, Bild 3 von 3
    • Remove the 2 screws on the back of the case at the top and bottom
    • Slide the cover forward, then slide it out (here, to the left).
    • Insérez ici votre traduction
  3. Synology DS218play - a complete disassembly in rules, Removes disks from the bay: Schritt 3, Bild 1 von 2 Synology DS218play - a complete disassembly in rules, Removes disks from the bay: Schritt 3, Bild 2 von 2
    • Remove the 4 screws located on the side of each drive.
    • then just pull the drives out from the bay
  4. Synology DS218play - a complete disassembly in rules, The two parts of the case: Schritt 4, Bild 1 von 3 Synology DS218play - a complete disassembly in rules, The two parts of the case: Schritt 4, Bild 2 von 3 Synology DS218play - a complete disassembly in rules, The two parts of the case: Schritt 4, Bild 3 von 3
  5. Synology DS218play - a complete disassembly in rules, Removing the motherboard: Schritt 5, Bild 1 von 3 Synology DS218play - a complete disassembly in rules, Removing the motherboard: Schritt 5, Bild 2 von 3 Synology DS218play - a complete disassembly in rules, Removing the motherboard: Schritt 5, Bild 3 von 3
    • disconnect the fan cable
    • remove the 3 screws holding the motherboard in place.
  6. Synology DS218play - a complete disassembly in rules, Motherboard : processor side: Schritt 6, Bild 1 von 1
  7. Synology DS218play - a complete disassembly in rules, Motherboard : connector side: Schritt 7, Bild 1 von 1
Abschluss
To reassemble your device, follow the instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
fr en
100%
Hier starten ›
Sébastien
4.174 Reputation
6 Anleitungen geschrieben
AEM (ANIMA EX MACHINA) Mitglied von AEM (ANIMA EX MACHINA)
Business
1 Mitglied
14 Anleitungen geschrieben
2 Kommentare
Excellent tutoriel de démontage du NAS SYNOLOGY DS218Play. C'est assez simple, merci son auteur!
Miguel LGS - Antwort
I have an older Synology DS214play and I hoped this guide would mostly apply to that model. The DS214play has one screw on the back panel that secures the outer shell. The guide for the DS218+ contains a rear panel that is more like the DS214play, with one screw and an eSATA port. Still, thanks for the clear instructions and photos.
Qrash - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 46
Letzte 30 Tage: 127
Insgesamt: 4,890
