Zum Hauptinhalt wechseln
Syntus ST150 Ultrasonic Plate Replacement
Was du brauchst
  1. Syntus ST150 Ultrasonic Plate Replacement, Ultrasonic Plate: Schritt 1, Bild 1 von 1
    • First, make sure the water tank inside the diffuser is completely dry to avoid any water from contacting the internal components.
    • Make sure the diffuser is disconnected from the power source to avoid electrical hazards.
  2. Syntus ST150 Ultrasonic Plate Replacement: Schritt 2, Bild 1 von 2 Syntus ST150 Ultrasonic Plate Replacement: Schritt 2, Bild 2 von 2
    • With a Phillips #1 screwdriver, remove the three 10 mm screws on the bottom of the diffuser.
  3. Syntus ST150 Ultrasonic Plate Replacement: Schritt 3, Bild 1 von 3 Syntus ST150 Ultrasonic Plate Replacement: Schritt 3, Bild 2 von 3 Syntus ST150 Ultrasonic Plate Replacement: Schritt 3, Bild 3 von 3
    • Lift the water tank while holding the base of the diffuser.
    • Disconnect the three cables form the board.
    • Make sure when reassembling the diffuser to plug in each cable to its assigned port.
  4. Syntus ST150 Ultrasonic Plate Replacement: Schritt 4, Bild 1 von 3 Syntus ST150 Ultrasonic Plate Replacement: Schritt 4, Bild 2 von 3 Syntus ST150 Ultrasonic Plate Replacement: Schritt 4, Bild 3 von 3
    • To separate the board from the water tank, unscrew the three Phillips #1 10 mm screws securing the board.
  5. Syntus ST150 Ultrasonic Plate Replacement: Schritt 5, Bild 1 von 3 Syntus ST150 Ultrasonic Plate Replacement: Schritt 5, Bild 2 von 3 Syntus ST150 Ultrasonic Plate Replacement: Schritt 5, Bild 3 von 3
    • With a Phillips #0 screwdriver, remove the three 7 mm screws from the ultrasonic sensor cover.
    • Remove the cover to expose the ultrasonic sensor.
  6. Syntus ST150 Ultrasonic Plate Replacement: Schritt 6, Bild 1 von 3 Syntus ST150 Ultrasonic Plate Replacement: Schritt 6, Bild 2 von 3 Syntus ST150 Ultrasonic Plate Replacement: Schritt 6, Bild 3 von 3
    • Detach the ultrasonic sensor from the water tank.
    • Detach the ultrasonic sensor connector from the board.
  7. Syntus ST150 Ultrasonic Plate Replacement: Schritt 7, Bild 1 von 1
    • Remove the rubber cover from the ultrasonic plate.
  8. Syntus ST150 Ultrasonic Plate Replacement: Schritt 8, Bild 1 von 1
    • Now you can replace the ultrasonic plate of your diffuser.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 333
