Zum Hauptinhalt wechseln
T-Mobile Sparq SIM Card Replacement
Was du brauchst
  1. T-Mobile Sparq SIM Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
  2. T-Mobile Sparq SIM Card Replacement: Schritt 2, Bild 1 von 1
    • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Insert the tip of your finger into the groove and gently lift the battery from the case.
  3. T-Mobile Sparq SIM Card Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • Once the battery has been removed the SIM card is easily accessible. Press your finger gently on top of the exposed SIM card and slide it in the direction of the battery compartment until it comes out.
Abschluss
LeAnn Lewis
539 Reputation
4 Anleitungen geschrieben
IUPUI, Team S3-G3, Wilson Spring 2018 Mitglied von IUPUI, Team S3-G3, Wilson Spring 2018
IUPUI-WILSON-S18S3G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 204
