Einleitung
This is how to replace the battery on a TCL Stylus 5G.
Was du brauchst
Press and hold the Power button for 2 seconds.
Then, select "Power off".
Insert a jimmy tool into the casing to create a gap.
Then, put a plastic pick in the gap and remove the jimmy tool.
Finally, lift up to remove the panel.
Remove the 10 Phillips screws holding the plastic shielding from the motherboard.
Then, grab a pick and put in in the slot show on picture 2.
You should then be able to lift the rest of it off.
Pull on the sticker located on the middle of the left side (colored green) of the battery to remove it.
NOTE: The pull tab may have resistance.
3 Kommentare
Lg syluis is a non removeable battery
Its a non removeable battery phone,unless u control it with a chiness &&^&@@ dumb ass move battery
No removeable
