Was du brauchst
Obtain the T5-bit from the toolkit and assemble the screwdriver.
Turn the speaker to the back and open the stand.
Located at the base of the stand are three 3-mm Torx screws.
Remove the three 3-mm Torx screws with the T5-bit screwdriver.
Gently pull the stand out after removing all the screws.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
