Einleitung
Replacing the control pad is simple and straightforward. A sharp, thin tool is needed, and some glue might be required to replace the control pad if it isn't sticking properly to the speakers.
Was du brauchst
Push the nylon or metal spudger under the corner of the control pad. This might take some patience, but it gets easier once the spudger gets under the control pad.
Slide the nylon or metal spudger along the long edge of the control panel, up to the next edge.
Grab the corner of the control pad and peel it off slowly. You should be able to see the circuit board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
