Einleitung
The speaker guard on the A33 speaker can be removed and replaced fairly easily. A thin tool is required for this guide.
Was du brauchst
Push the nylon or metal spudger in the corner of the speaker guard.
Slowly lift the speaker up enough so that you can slide around the speaker guard.
Remove the speaker guard. You can now replace the speaker guard on your TDK Life on Record A33.
Fast fertig!
Abschluss
