Was du brauchst
Remove the four rubber feet of the device using a metal spudger.
Remove the four 9 mm Phillips #0 screws located under the feet of the device.
Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
Pull apart the compartments by applying force in opposite directions.
place your hands on each side of the air vent and then place your index finger on the thin plastic half circle that holds the vent in place.
Pull the plastic half circle towards you.
Put both of your hands inside the tube as shown and push away from you.
Remove the four wired clips by pulling on the wires.
Remove the three 6 mm Phillips #1 screws.
Remove the volume control knob, which is located at the front of the speaker, by pulling it towards you.
Using tweezers, turn the nut counter-clockwise and remove the nut.
Use your left hand to hold the top portion of the speaker in place.
Using your right hand, pull the handle away from the device.
