Zum Hauptinhalt wechseln
TDK Life on Record Trek Max A34 Battery Replacement
Was du brauchst
  1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: Schritt 1, Bild 1 von 2 TDK Life on Record Trek Max A34 Battery  Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Battery  Replacement: Schritt 2, Bild 1 von 2 TDK Life on Record Trek Max A34 Battery  Replacement: Schritt 2, Bild 2 von 2
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Battery  Replacement: Schritt 3, Bild 1 von 3 TDK Life on Record Trek Max A34 Battery  Replacement: Schritt 3, Bild 2 von 3 TDK Life on Record Trek Max A34 Battery  Replacement: Schritt 3, Bild 3 von 3
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Battery  Replacement: Schritt 4, Bild 1 von 2 TDK Life on Record Trek Max A34 Battery  Replacement: Schritt 4, Bild 2 von 2
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Battery  Replacement: Schritt 5, Bild 1 von 1
    • The battery is now separated from the device and may be replaced with a new battery.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Kayla
315 Reputation
1 Anleitung geschrieben
Texas Tech, Team 19-3, Rauch Fall 2015 Mitglied von Texas Tech, Team 19-3, Rauch Fall 2015
TTU-RAUCH-F15S19G3
4 Mitglieder
2 Kommentare
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
John Johnston - Antwort
my problem of my trek max unit
everytime recharge my trek max is hot.
Wilfredo Natividad - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 50
Insgesamt: 11,343
