Zum Hauptinhalt wechseln
TI-84 Plus Disassembly
Was du brauchst
  1. TI-84 Plus Disassembly, flip: Schritt 1, Bild 1 von 2 TI-84 Plus Disassembly, flip: Schritt 1, Bild 2 von 2
    • Be sure the calculator is powered off before proceeding.
    • Take off the sliding cover, and flip your calculator to the back side.
  2. TI-84 Plus Disassembly, battery plate.: Schritt 2, Bild 1 von 2 TI-84 Plus Disassembly, battery plate.: Schritt 2, Bild 2 von 2
    • Press down on the latch, then remove the battery cover.
  3. TI-84 Plus Disassembly, take out the batteries: Schritt 3, Bild 1 von 2 TI-84 Plus Disassembly, take out the batteries: Schritt 3, Bild 2 von 2
    • Remove the batteries.
    • You can use the battery cover as a plate to keep the batteries.
  4. TI-84 Plus Disassembly, back up battery: Schritt 4, Bild 1 von 3 TI-84 Plus Disassembly, back up battery: Schritt 4, Bild 2 von 3 TI-84 Plus Disassembly, back up battery: Schritt 4, Bild 3 von 3
    • Removing this battery will clear your RAM, so be sure that you have made any backups of important data.
    • Use a Phillips #0 to remove the plate from the back up battery.
  5. TI-84 Plus Disassembly, backup battery: Schritt 5, Bild 1 von 2 TI-84 Plus Disassembly, backup battery: Schritt 5, Bild 2 von 2
    • remove the backup battery with either a screwdriver or the spudger.
  6. TI-84 Plus Disassembly: Schritt 6, Bild 1 von 1
    • you can use a t6 or tr6 take out all six marked screws
  7. TI-84 Plus Disassembly, cracking the case: Schritt 7, Bild 1 von 3 TI-84 Plus Disassembly, cracking the case: Schritt 7, Bild 2 von 3 TI-84 Plus Disassembly, cracking the case: Schritt 7, Bild 3 von 3
    • Use a prying tool to get a pick into the side and then move it down until its open.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Nice! My calculator wasn't turning on, took it apart and rebent the contacts for the batteries, works great now!
Noah Molla - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 49
Letzte 30 Tage: 222
Insgesamt: 8,638
