Zum Hauptinhalt wechseln
TI-84 Plus Silver Edition Backup Battery Replacement
Was du brauchst
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: Schritt 1, Bild 1 von 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: Schritt 1, Bild 2 von 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: Schritt 1, Bild 3 von 3
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: Schritt 2, Bild 1 von 1
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: Schritt 3, Bild 1 von 1
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: Schritt 4, Bild 1 von 1
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: Schritt 5, Bild 1 von 2 TI-84 Plus Silver Edition Backup Battery Replacement: Schritt 5, Bild 2 von 2
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
Abschluss
17 weitere Nutzer:innen haben diese Anleitung absolviert.
Agustin
1.028 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 11-34, Amido Fall 2013 Mitglied von Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Mitglieder
6 Anleitungen geschrieben
9 Kommentare
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Antwort
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Antwort
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Antwort
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 70
Letzte 30 Tage: 309
Insgesamt: 65,991
