Zum Hauptinhalt wechseln
TI-84 Plus Silver Edition Battery Spring Replacement
Was du brauchst
  1. TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: Schritt 1, Bild 1 von 2 TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: Schritt 1, Bild 2 von 2
    • Unscrew all six 8.5mm screws in the back of the calculator using the T6 star screw bit.
  2. TI-84 Plus Silver Edition Battery Spring Replacement: Schritt 2, Bild 1 von 2 TI-84 Plus Silver Edition Battery Spring Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry the calculator open.
    • Use your hands to firmly grasp and pull apart the calculator when a reasonable gap has been made.
  3. TI-84 Plus Silver Edition Battery Spring Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery in order to access the battery spring that needs to be replaced.
  4. TI-84 Plus Silver Edition Battery Spring Replacement: Schritt 4, Bild 1 von 1
    • Remove the damaged spring using the tweezers.
  5. TI-84 Plus Silver Edition Battery Spring Replacement: Schritt 5, Bild 1 von 2 TI-84 Plus Silver Edition Battery Spring Replacement: Schritt 5, Bild 2 von 2
    • Pick up the new spring with the tweezers.
    • Insert the new spring with the tweezers.
    • Gently push the new spring into place using your finger.
  6. TI-84 Plus Silver Edition Battery Spring Replacement: Schritt 6, Bild 1 von 1
    • Test by replacing the battery that was taken out to check the connection.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Hi! So where can I get the spring part?
Aleyson B.Hunter - Antwort
Hey! You can make a fix by bending a bit of stripped copper wire. I uploaded some Images of my fix, it worked reliably you just had to be careful when replacing batteries.
However i have found my original spring. But whiles searing for one to buy i stumble on many on Aliexpress that you could bend to the correct shape, Maybe this FW-DCTHZ9X20 (Seller) would work as the end part of the original spring is as well 9 mm.
Julian Lundh -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 652
