Zum Hauptinhalt wechseln
TI-84 Plus Silver Edition Faceplate Replacement
  1. TI-84 Plus Silver Edition Faceplate Replacement, Faceplate: Schritt 1, Bild 1 von 1
    • Insert your index finger in the open slot below the keys.
    • Be careful to not bend the plate too much because it is very thin and might break.
    • Apply a firm upward force until the bottom two tabs located near the bottom of the plate come off.
  2. TI-84 Plus Silver Edition Faceplate Replacement: Schritt 2, Bild 1 von 1
    • Grab the face plate on each side near the middle and apply a gentle upward force on each side until the middle tabs come off.
    • A tab is located in the center of the face plate. If it is still attached, then continue to apply a gentle upward force until the center tab comes off.
    • Lift the face plate upward until the top three tabs come off and the face plate is completely detached.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Agustin
1.041 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 11-34, Amido Fall 2013 Mitglied von Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 10,694
