Einleitung
Replacing a wheel on a TILT pro scooter is a common maintenance task that any rider should know how to do. Whether you're upgrading your wheels or replacing a damaged one, it's important to know the steps to ensure a smooth and safe ride. In this guide, we'll take you through the necessary steps to replace a wheel on your pro scooter. You'll need a few tools and a bit of patience, but with this guide, you should be able to replace your wheel in no time.
Was du brauchst
Flip your scooter upside down where the handle bars and wheels touch the ground to prepare the extraction of the wheel.
Turn the scooter to the opposite side, and insert and push the Y-tool through the same hole where the screw was removed to extract the parts.
Insert the new wheel and adjust the optional 10mm hex nut to support the wheel's.
Insert the axle from which ever side and the opposite side to help adjust the hex nuts as you insert the axle easily.
Flip your scooter upside up and move your scooter around to detect any lose movement.
To reassemble the wheel from the back of the scooter repeat step 1, follow the instructions similar to the front wheel.
Eine weitere Person hat diese Anleitung absolviert.
